85 Users Online (83 Members): Show Users Online - Most ever was 626 - Mon, Jan 12, 2015 at 2:00:17 PM
Forums >> Revit Systems >> Technical Support >> Structural columns and most walls are black in camera view.
Tue, Mar 25, 2008 at 7:07:28 AM | Structural columns and most walls are black in camera view.
ottomatic
ottomatic Avatar
1 Stars: 1 Votes
Everything shows up normally in the default 3D view, but in camera view my structural columns and most of my walls are blacked out.  Anyone know what is causing this?
Tue, Mar 25, 2008 at 11:21:30 AM | Structural columns and most walls are black in camera view.
castle
castle Avatar
4 Stars: 6 Votes
When you're setting up your camera view, are you sure what you want to show is in the camera view lines?  You might have to drag it out further to include everything you want to show.  Anyone else with ideas?
Tue, Mar 25, 2008 at 1:10:49 PM | Structural columns and most walls are black in camera view.
mhans
3 Stars: 10 Votes
Is your column wood or concrete? Check your Element properties, Surface pattern. If there's an entry of hatch pattern try removing it for now. You can switch view detail to coarse or medium to observe the effect.
Motto: "No Post left behind"
Thu, Mar 27, 2008 at 1:02:04 PM | Structural columns and most walls are black in camera view.
ottomatic
ottomatic Avatar
1 Stars: 1 Votes
Everything I want to show is within camera view, and it shows up but it's just blacked out.  As for the columns, I had a bit of a brain fart and didn't zoom in before I posted this, so those are fine, however my walls are still black.  Everything shows up fine upon rendering so it's not a real issue, just an annoyance.  Thanks anyway for the suggestions.  If anyone knows why my walls are blacked out I'd still love to know.  By the way I'm using Revit architecture 2008.
Cut Pattern - Timber Columns in plan views to black ?
Tue, Mar 18, 2014 at 7:41:46 PM
structural wall VS structural columns
Tue, Apr 26, 2016 at 3:49:39 PM
Structural Columns not cutting walls
Mon, Jan 4, 2016 at 4:13:25 PM
problem joining walls and structural columns in Revit 2009
Tue, Mar 16, 2010 at 6:27:19 PM
Strucutral Columns VS Walls in Call outs
Mon, Aug 16, 2010 at 8:17:05 AM
Page generation time: 13.7344
