88 Users Online (87 Members): Show Users Online - Most ever was 626 - Mon, Jan 12, 2015 at 2:00:18 PM
Forums >> Revit Building >> Technical Support >> Attaching walls to stairs
Wed, Mar 16, 2005 at 8:23:18 AM | Attaching walls to stairs
gimmecat
I was trying to build a small bathroom on the underside of a staircase. I can attach the wall to the staircase by editing the profile. But my question is how do I attach the smaller wall to the underside of the stairs? (see attachment) I end up with it either penetrating the stairs or not attaching as I want it to... Another question. I've seen Mr Spot's tutorial on how to attach a wall to a curved stair (great tutorial as usual;Winking But is there any simpler way to do it?
Wed, Mar 16, 2005 at 9:21:36 AM | RE: Attaching walls to stairs
ale02
ale02 Avatar
3 Stars: 3 Votes
I think you can try do a section thru the staircase, open up the section and create a in-place wall family using extrude and just align the sloped/ parallel line to the underside of the staircase... btw, where to find Mr. Spot's tutorial on the attaching wall to the curved stairs...link please & thanks
Life is never easy but nor it should be complex. Just stay simple Smile
Wed, Mar 16, 2005 at 5:22:41 PM | RE: Attaching walls to stairs
gimmecat
I'm attaching it. I took it from the AUGI foruns but since the author is also a member in revitcity I suppose he won't mind. If you are Mr.Spot and you do mind about it, please just say so and I'll remove it immediatly. The tutorial's great but is there an easier way to do it?
Wed, Mar 16, 2005 at 5:37:11 PM | RE: Attaching walls to stairs
Mr Spot
Mr Spot Avatar
4.5 Stars: 93 Votes
Nope i don't mind, i actually uploaded the tutorial here about 6 weeks ago now but still hasn't shown up. Guess the guys are really busy working on the site... in elevation, draw a reference plane to align with underside of the stair then select the wall and use attach top to attach the wall to the reference plane. HTH.
Wed, Mar 16, 2005 at 6:44:36 PM | RE: Attaching walls to stairs
gimmecat
HTH.I know this works with straight stairs, but my question was if there was an easier way to do this on spiral stairs other than the tutorial you made.
Wed, Mar 16, 2005 at 7:04:21 PM | RE: Attaching walls to stairs
Mr Spot
Mr Spot Avatar
4.5 Stars: 93 Votes
Not currently. Other method it to split the wall at each tread and then drag the top down to the underside of the stair (but if you have a smooth underside than my tutorial is currently the only way). Try the Revit 8 beta...
Wed, Mar 16, 2005 at 7:16:08 PM | RE: Attaching walls to stairs
gimmecat
oh I would, if I knew where to get it!
Wed, Mar 16, 2005 at 7:53:19 PM | RE: Attaching walls to stairs
Mr Spot
Mr Spot Avatar
4.5 Stars: 93 Votes
Subscription members should have received an email in the last day or so about the current beta program. Official release is scheduled for April 22nd along side the structural package.
Wed, Mar 16, 2005 at 10:35:30 PM | RE: Attaching walls to stairs
gimmecat
Since I'm not a subscription member seems I'll have to wait for the oficial release. sigh...
Thu, Mar 17, 2005 at 1:31:41 AM | RE: Attaching walls to stairs
ale02
ale02 Avatar
3 Stars: 3 Votes
gimmecat & Mr.Spot, Thanks for the pdf & the tips too
Fri, Jan 2, 2015 at 7:37:30 AM | Attaching walls to stairs
hydyr96
4.5 Stars: 8 Votes
PAL, THE BEST AND THE ,UNFORTUNATELY, MOST "EASIEST" WAY IS TO CREATE A MASS SURFACE AND APPLY WALL BY SURFACE
Tue, Jul 28, 2015 at 1:35:01 PM | Attaching walls to stairs
AlDurante
I know this thread goes back to 2005, but I have to thank you guys who posted the tips for this process, never knew I could use reference planes for this sort of thing.  MUCH appreciation!
Morganne
Wed, Feb 24, 2016 at 2:37:56 PM | Attaching walls to stairs
#13
sicko
Modeled a "roof" component to use as a stone cap and attatched the wall top to this.  Might be useful in some of these situations.
Tue, Aug 22, 2017 at 12:20:11 AM | Attaching walls to stairs
#14
zakazai
Hi
I just created a 1mm thick floor below the stair. using shape editing tool1
then i attached wall to the floor. then i gave the same material of stair to the floor
then attach the wall to top
Attaching Rails to walls
Thu, Aug 13, 2009 at 12:59:43 PM
Attaching walls to the bottom of stairs
Wed, Aug 24, 2011 at 10:15:56 AM
Attaching Curved walls to underside of Curved Stairs
Wed, Sep 12, 2012 at 12:43:48 PM
attachig walls to circular stairs
Wed, Feb 13, 2013 at 4:17:34 AM
Attaching Railign to stairs...
Sun, Jan 23, 2011 at 8:59:02 AM
Page generation time: 0.9797
