66 Users Online (63 Members): Show Users Online - Most ever was 626 - Mon, Jan 12, 2015 at 2:00:18 PM
Forums >> Revit Building >> Technical Support >> revit walls
Mon, Mar 24, 2008 at 2:26:05 PM | revit walls
JR49
HOW CAN I MAKE MY WALL TYPES LOOK LIKE THE ONES IN THE USG WEBSITE UNDER DESIGN STUDIOS, THEY MANAGE TO PUT COLOR TO REPRESENT THE GWB AND STUD FRAMING
Mon, Mar 24, 2008 at 3:02:45 PM | revit walls
brettgoodchild
brettgoodchild Avatar
4 Stars: 17 Votes
This can be done by assigning a solid fill pattern to the stud / gyp. layers in the wall structure.
To do this, pick the wall and go into the properties. Hit EDIT / NEW to go into the type properties.
Next, where it says STRUCTURE, click EDIT to the right and this will bring you into the EDIT ASSEMBLY dialog.
From here all you have to do is edit the material by clicking on it and assign a colored, solid fill pattern to the material.
HTH
"You cannot escape the responsibility of tomorrow by evading it today. "
                             ~ Abraham Lincoln
Tue, Mar 25, 2008 at 6:44:22 AM | revit walls
JR49
thanks alot, that really helped
Tue, Mar 25, 2008 at 6:49:59 AM | inserting ttf font to revit
JR49
i have another question if you dont mind answering, how can i insert TTF font(true type fonts) in revit. i downloaded afew but i dont know how to insert it. i need these fonts because they are the closet thing to what my office uses now.
Tue, Mar 25, 2008 at 7:37:33 AM | revit walls
coreed
coreed Avatar
4 Stars: 16 Votes
you install your fonts into operating system, not Revit. then the fonts should available to Revit thru the OS
HTH
Edited on: Tue, Mar 25, 2008 at 7:37:50 AM
best regards,
coreed,aia
bmpArchitects,Inc.
Long Live Revit
Tue, Mar 25, 2008 at 10:20:43 AM | revit walls
brettgoodchild
4 Stars: 17 Votes
As coreed said, you don't install the fonts Revit reads the windows font file. To do this, just copy the fonts into
WINDOWS > FONTS. The next time you start Revit the fonts will be available to use.
                             ~ Abraham Lincoln
Tue, Mar 25, 2008 at 12:15:21 PM | revit walls
JR49
thanks alot fellows it help alot
See-through walls? I can't make the walls solid.
Wed, Jan 9, 2013 at 12:55:18 PM
Attaching Rails to walls
Thu, Aug 13, 2009 at 12:59:43 PM
Walls
Thu, Dec 16, 2004 at 4:56:58 PM
Why do Revit walls hate me?
Tue, Feb 6, 2007 at 4:33:40 PM
Angled Walls in Revit
Mon, Jan 12, 2015 at 8:48:27 AM
Page generation time: 1.7699
