103 Users Online (99 Members): Show Users Online - Most ever was 626 - Mon, Jan 12, 2015 at 2:00:18 PM
Forums >> Revit Building >> Technical Support >> Changing Dimensions
Sun, Mar 23, 2008 at 7:15:00 PM | Changing Dimensions
crpone
I am trying to change the dimensions to my drawing.  ther are not locked and I have clicked on every wall around the walls that I am trying to change the dimensions to and I am still unable to change the dimensions.  I have unlocked all the walls around the structure in an attempt to change the dimensions but I was unsuccessful.  I have even tried the "activate dimension" feature.  that did not work at all either.  What should I do?
Mon, Mar 24, 2008 at 5:45:10 AM | Changing Dimensions
JHanby
3.5 Stars: 3 Votes
Have you tried to highlight the dimension, then click on the blue dot that says "Move witness line" when you hover over it.  Click that dot and move the line where you want.  You might have to stretch out the extension line in order to see that dot, it will be in the midddle of the extension line.  HTH
Mon, Mar 24, 2008 at 7:58:33 AM | Changing Dimensions
First, dimensions in REVIT are parametric.  You don't change the dimension, you move the item that is dimensioned.
Second, when dimensioning, you have to make sure what you are dimensioning.  Several things may exist at the same point so pay attention to what you are picking in the lower left corner of your screen.  You may have to tab through several items to get what you want.  This will be true at each dimension point.
Third, assuming you have dimensioned correctly, click on the item (wall) you want to move.  Then click "activate dimensions" on your options bar.  Your dimension will change to blue and you can now change the dimension which will move your item (wall).
This may seem ackward at first but after you have worked with it awhile, you will really like it.
Sat, Feb 5, 2011 at 5:03:27 PM | Changing Dimensions
trytoh
hi guys
I have a question if you please
can I pass the wall thikness dimension when am using the entire wall way , I mean I just want revit to give me the rooms dimension by few clicks with the entire wall dimension way
it's really important , so helllllllllllllllllllllllllp
thank you
Sun, Feb 6, 2011 at 9:59:39 AM | Changing Dimensions
When you are dimensioning to a wall, use your tab key to select what you want to dimension to - wall centerline, core centerline, face of wall....
Sun, Feb 6, 2011 at 1:54:17 PM | Changing Dimensions
trytoh
thank you wwhub but have you noticed that I said by using the entire walls way ...
your way is the normal way and it's not far away from the autocad way but the strength of revit that he can do this operation by one or two click by using the entire walls way and mark the intersecting walls option but the problem which is hapening with me that he doesn't pass the wall dimension and it's really not necessary to me and makes the plan crowded so do you have any idea to solve this problem???
thank you anyway my dear
Mon, Feb 7, 2011 at 7:24:47 AM | Changing Dimensions
Not sure what you are asking.  Are you wanting to eliminate the wall thickness dimension in this string?  If so, you can't.
Mon, Feb 7, 2011 at 9:02:53 AM | Changing Dimensions
bert
Trytoh, when in dimension mode, check the options toolbar.
Great Revit karma will come to you for answering my many questions.
using RAC-2013
Blog: Revit Templateer
Changing dimensions
Tue, Dec 22, 2015 at 5:05:10 AM
Maintaining interior dimensions when changing walls
Mon, Mar 16, 2009 at 11:19:26 AM
Changing the Set dimensions for a window
Thu, Feb 7, 2008 at 8:40:55 PM
Isometric Dimensions in Drafting Views (details)
Fri, Sep 28, 2012 at 3:13:09 PM
Changing Dimension object in Array
Thu, Jul 27, 2017 at 6:05:06 AM
Page generation time: 0.5636
