After accepting License Agreement, When I press Install button to install the "Cabinets File" then "Content Extraction Dialog" reports the following errors abut errorneous cabinets, Pressing Skip or Retry doesnt solve error: - Error: The data is invalidChoose to Retry to skip Cabinet "C:\Document\Amit\Locals\Temp\ENUHelp.cab" When I press Skip, then other error appears: - Error: The data is invalidChoose to Retry to skip Cabinet "C:\Document\Amit\Locals\Temp\IntMetTempl.cab" When I cancel Cabient installation process then, a dialog appears that RAC 2008 is successfully installed but when I run the application then it give error that - "AccuRender rendering feature is not available because the Accurender library could not be found on your computer. Please check the AccuRender resource path set in settings> Option dialog" After it another error appears that the default template file specified in the "File Location" section of the> Setting>Options Dialog (C:\Document & Settings\All User\Application Data\Autodesk\RAC 2008\Metric Templates\DefaultUs-Canada.rte) does not exist. Other error appearas that: - Some of the Revit Content that you chose to install was not successfuly installed, do You want to try and install the content again. When I press Yes to install the require content then the same error occur that: - Error: The data is invalidChoose to Retry to skip Cabinet "C:\Document\Amit\Locals\Temp\ENUHelp.cab" When I press Skip, then other error appears: - Error: The data is invalidChoose to Retry to skip Cabinet "C:\Document\Amit\Locals\Temp\IntMetTempl.cab" RAC is installed porperly but except the Templates & Cabinet files. I checked in RAC 2008> Settings>Options>File Location>Default Template File then Press Browse for looking of defaultUS-Canada.ret, But this template is not exist.Pls tell how to install cabients file without any error.
