Forums >> Revit Building >> Technical Support >> Plate with holes_type parameter in family
46 Posts No Rating |
I am trying to create a simple steel plate with holes. I can create the family to have a thickness, width, height and even length. However, I would like to be able to have the option of hole locations, dia and even better, number of holes. I cant seem to get the void(circle) to "lock" to a ref. line. When I flex the family, just the ref. line moves and not the circle void. Also how to be able to set the specific hole size does not work well either. How would I go about having the option for one, two or three holes...or should that just be a seperate family? I know some of you experts out there can do this in your sleep...thanks for you help
63 Posts No Rating |
Hi, Edit the hole, when the circle is visable select it, then go to it properties & tick the box 'Centre Mark Visable' now you can aling & lock the centre mark to a RPlane you can also add a radial dimension to the circle & make a parameter of it. Best of luck John A
you can control the number on an array with a parameter integer if your circles are in line with each other, and to control wheather they will cut make the hole ) you can set your void to -5 outside the volume that needs to be cut and link the other void length parameter to an 'if parameter formula' linked to a checkbox, if (circles cut,80,0) circles cut is the name of the parameter with the checkbox
"There is no path to peace,
peace is the path."
Mahatma Gandhi.
That was super helpful for me too as I tried to add button tufting to a furniture family and it wouldn't flex properly. thsi solved that problem too! thanks!
? Passing parameter values either between hosted families or nested families ? |
Tue, Dec 21, 2010 at 2:21:48 PM
Sill plate? |
Thu, Jan 28, 2010 at 5:10:17 PM
Attaching a footing to a column with a base plate nested into the footing family |
Thu, Jul 11, 2019 at 12:23:43 PM
How to Show a Recess of an Embed Plate |
Wed, Mar 25, 2015 at 2:25:56 PM
Column base plate tag units display. |
Mon, Nov 17, 2014 at 2:24:41 PM
Members: | 2099020 | Objects: | 23170 | Forum Posts: | 152292 | Job Listings: | 3 |
