54 Users Online (53 Members):
Forums >> Revit Structure >> Technical Support >> Angled column??
1 Posts No Rating |
Hi I'm a Revit newbie and I can't figure out how to angle a column to support a shelf. The columns are not structural but decorative walls - any ideas to make that work?
If they are really decorative walls then make them walls and edit the elevation profile on both side to make them "angle"
It sounds like you are making a column like object but using the Wall tool to create it. If so, you are in luck. You could use the Massing tools to create a Mass with one face in the Angle and Position that you would like for your 'Wall' to be. Then, use the Wall by Face tool, in the Massing Tab, to place the walls on the face at the desired angle. If however, you are using the Architectural Coulmn tool, then you might need to edit the family to get it to angle. Remember to 'Dissociate from Plane' before rotating the objects. Hope this helps at least a little. Keep me posted.
----------------------------------- ArchWestCY |
Making Angled or canted walls |
Tue, Jun 3, 2008 at 2:10:07 PM
How to extend top flange of beam (over top of column)? |
Fri, Jun 15, 2012 at 10:35:08 AM
angled corner joint - how to lock angled corners |
Thu, Jul 18, 2013 at 5:10:11 AM
11
Column Grid Text |
Tue, Dec 11, 2007 at 9:33:36 AM
slanted model in place column |
Sun, Nov 7, 2010 at 9:01:37 PM
Members: | 2042240 | Objects: | 23026 | Forum Posts: | 152217 | Job Listings: | 3 |
