83 Users Online (82 Members):
Forums >> Revit Building >> Technical Support >> Wall hatch pattern
2 Posts No Rating |
I'm putting my first project into Revit, so I don't know a lot yet. I have my elevations and plans finished, but can't find a way to get the gypsum hatch pattern to show up on the RCP and not on my elevations. I've tried different things with the pattern and cut pattern options in the properties box, but when I change the properties of the walls, the properties of the ceiling change with it. Any suggustions? Thanks! (Revit Architecture 200
In your View Properties, under Visibility/Graphics, you can turn off the surface patterns for walls (but that will turn off all wall surface patterns) To do that, select Walls, to the right, under Projection/Surface, click Override on the Surface side, and uncheck visible. If you want JUST the gyp bd to be hatched/unhatched, I'd make a new material that has no pattern. Hope that helps.
Ruth Rau Main Street Architecture, P.C. |
Vertical hatch pattern line alignment on wall ends |
Wed, Mar 14, 2012 at 10:04:07 AM
CMU Hatch Patern |
Sat, Jan 31, 2009 at 4:00:05 AM
Getting Cut Wall Hatch to move WITH the Wall |
Fri, Aug 10, 2012 at 2:59:50 PM
Orientation of Hatch files |
Fri, Sep 15, 2006 at 12:54:43 PM
Exporting hatch pattern |
Thu, Sep 18, 2014 at 6:27:35 PM
Members: | 2056445 | Objects: | 23069 | Forum Posts: | 152325 | Job Listings: | 3 |
