35 Users Online (32 Members): Show Users Online - Most ever was 626 - Mon, Jan 12, 2015 at 2:00:17 PM
Forums >> Revit Building >> Technical Support >> Add rotate parameter by roof pitch not degrees
Wed, Mar 19, 2008 at 10:21:40 AM | Add rotate parameter by roof pitch not degrees
lorne17
lorne17 Avatar
3.5 Stars: 7 Votes
I have created an exposed rafter tail and i am curious if we can place a parameter that we can say type in 3:12 for the rotation.  right now we have degrees and if our roof is say 4:12 then we have to calculate it and type the degrees in to 18.43.
PLMK.  ThankS,
Lorne
Denver, CO
Revit Architecture
Tue, Apr 8, 2008 at 2:41:31 PM | Add rotate parameter by roof pitch not degrees
lorne17
lorne17 Avatar
3.5 Stars: 7 Votes
Anybody?  Is this possible?  It would really be helpful to place in our family, because we indicate roof slopes by 3:12, or 4:12, etc.  Not Degrees.  Thanks
Denver, CO
Revit Architecture
Tue, Apr 8, 2008 at 2:45:39 PM | Add rotate parameter by roof pitch not degrees
Is this a family element or do you just want to know how to rotate it in elevation?
Tue, Apr 8, 2008 at 3:01:30 PM | Add rotate parameter by roof pitch not degrees
lorne17
lorne17 Avatar
3.5 Stars: 7 Votes
Family element.  I have created twofamilies that need to have the slope of roof specified.  One, is an exposed tapered rafter tail that needs to obviously bet the same slope as the roof.  Two, we have created a trapeziod window that we need the top of the window to run parellel with the roof slope above.
Make sense?  It's not in elevation.  It's a parameter from the family.
Denver, CO
Revit Architecture
Tue, Apr 8, 2008 at 3:25:26 PM | Add rotate parameter by roof pitch not degrees
dano3d
3.5 Stars: 3 Votes
Did you try creating a parameter that uses a trig function conversion .
See the attached simple family example.
Dan-o
Tue, Apr 8, 2008 at 4:02:27 PM | Add rotate parameter by roof pitch not degrees
lorne17
lorne17 Avatar
3.5 Stars: 7 Votes
That is EXACTLY what I needed.  Thanks so much Dano Smile
Lorne
Denver, CO
Revit Architecture
Tue, Apr 8, 2008 at 4:11:28 PM | Add rotate parameter by roof pitch not degrees
dano3d
3.5 Stars: 3 Votes
you're welcome lorne17.
I just wanted to tell you that I've taken a visit to your firm's website.
Very nice work you're doing down there in Texas!!!
Tue, Apr 8, 2008 at 4:18:42 PM | Add rotate parameter by roof pitch not degrees
lorne17
lorne17 Avatar
3.5 Stars: 7 Votes
Thank you Dano,
We appreciate that.  I'll be sure to pass that along.  Smile
Lorne
Denver, CO
Revit Architecture
another double pitch roof question!
Thu, Jun 14, 2007 at 10:42:50 AM
Adding PITCH to a Curved/Barrel-Vaulted Roof
Thu, Feb 21, 2008 at 8:21:25 PM
Duel Pitch Roof
Tue, Feb 10, 2009 at 2:11:10 PM
Bay window roof pitch
Fri, Apr 7, 2006 at 1:01:50 PM
can't change roof pitch
Wed, Mar 18, 2009 at 9:47:54 AM
Page generation time: 2.1043
