Forums >> Revit Building >> Technical Support >> Portion of Room tags show up in one plan but all show up in another...
2 Posts No Rating |
My question is, and maybe I should be in the newbie section since that is what I am, but I have a floor plan where all of the room names and room numbers show up well. In the finish plan, only about 5 of the total rooms show up with the tags. This work was started by a guy who left our office so I'm trying to educate myself on Revit, and figure out what he did. I check the Visibility/Graphics Override function under Element Properties and I see that Room tags is checked in the finish plan. I can't imagine that I would have to copy them from the floor plan into the finish plan would I?
Check the Volume of those Rooms. Sometimes when people are new to the tools, they don't realize that a room has volume as well as area, and so don't check to make sure that the room goes from floor to ceiling. Cut a Section through the rooms that are not showing up, go to your Visibility/Graphics settings and make Rooms visible, then double check to make sure that your rooms actually go through where your cut plane is for the finish plan. Hope that helps.
Ruth Rau Main Street Architecture, P.C. |
2 Posts No Rating |
Thanks for the thought. I checked and the room definitely has volume. One thing I noticed when experimenting is that I can place a new room tag in the missing rooms and it will display correctly (with the correct room name and number). I wonder, is it possible that these were deleted for some reason from the finish plan but that they can still be visible in the floor plans? Brian
No doubt! Leave it to me to forget the simple answer. Yes, you can delete a room tag on one view and it will still show up on another.
Demo Plan Room Tags |
Thu, May 12, 2022 at 9:21:44 PM
Room Tags not showing up in Floor plan. |
Tue, Nov 9, 2010 at 1:06:50 PM
Room Tags( why will they not show in certain areas) |
Mon, Dec 10, 2007 at 6:15:35 AM
room tags in ceiling plan? |
Wed, Jun 14, 2006 at 4:30:44 PM
room tags to show dimension |
Mon, Oct 21, 2013 at 7:33:24 AM
Members: | 2118858 | Objects: | 23205 | Forum Posts: | 152311 | Job Listings: | 3 |
