128 Users Online (126 Members): Show Users Online - Most ever was 626 - Mon, Jan 12, 2015 at 2:00:18 PM
Forums >> Revit Building >> Technical Support >> Export Settings
Wed, Mar 19, 2008 at 12:23:23 AM | Export Settings
Nicolas
1 Stars: 1 Votes
Hi
I am currently trying to set up the dwg export settings.  I cant seem to find a catagory for filled regions.  I want to set the line color for a filled region pattern.
My real issue is that when I export a rather dense filled region from Revit and open it in AutoCAD and print, it becomes one solid patch.  I need to be able to set the line weight of the hatch out of Revit if possible!
Can someone assit me in this?
Nic
Wed, Mar 19, 2008 at 3:39:31 PM | Export Settings
BS0450
BS0450 Avatar
3 Stars: 1 Votes
In AutoCAD have a line type in mind that is set to print very light.
In Revit go to File > Import/Export Settings > Export Layers DWG/DXF
Look for the coorisponding item for wall cut patterns and change the color of line to what you want in AutoCAD
See image for what the dialogue looks like.
Hope this helps.
Export settings
Fri, Aug 12, 2005 at 8:42:17 PM
export radiosity settings and materials to viz
Wed, May 26, 2004 at 2:28:40 AM
renaming the export settings
Fri, May 7, 2010 at 8:51:03 AM
default export to DWG settings
Mon, Jul 2, 2012 at 2:38:14 PM
Revit Export to CAD
Mon, Jul 21, 2014 at 8:35:52 AM
Page generation time: 0.4605
