114 Users Online (113 Members): Show Users Online - Most ever was 626 - Mon, Jan 12, 2015 at 2:00:17 PM
Forums >> Revit Building >> Technical Support >> Different room tags in different views?
Mon, Mar 17, 2008 at 12:44:29 PM | Different room tags in different views?
violet78
violet78 Avatar
I want room names w/ numbers in most views, but on one plan I want to used room tags w/ area.  If I change the tag type, it's changing the tags in all the views.  Is there any way to do this?  Or, can I create an additional tag that would giv me only the square footage (no name or number)?  I would rather not create a separate area plan that I will need to keep updating.
Mon, Mar 17, 2008 at 12:55:10 PM | Different room tags in different views?
Your thoughts are correct .... just create a new type.  We have several types in our family with a visibile switch for the various parameters.
You can also create a new family that looks at the same information.  Good time to learn about parameters.
Mon, Mar 17, 2008 at 1:31:56 PM | Different room tags in different views?
violet78
violet78 Avatar
Ok...but if I add a room tag w/ area only to the single plan, how to I get it turned off in all the other plans?
Mon, Mar 17, 2008 at 2:49:55 PM | Different room tags in different views?
You can turn off all tags using VG.
BTW - an easy way to do tags is to do them in one plan .... lets say it's architectural - window the plan - filter it for room tags - copy to clipboard - paste them in your other view (maybe furnishings ... electrical).  While they are highlighted, you can change their type to the type you want.
Select room tags; copy rooms to new phase
Thu, Jun 29, 2006 at 7:19:48 AM
Room tags in section views
Tue, Sep 27, 2005 at 4:39:14 PM
Room Tags in RCPs
Sat, Feb 11, 2006 at 3:03:52 PM
ROOM TAGS
Fri, Jul 29, 2011 at 8:25:58 AM
2 views, only one room tag showing?
Tue, Jun 23, 2009 at 2:28:32 PM
Page generation time: 2.1887
