Forums >> Revit Structure >> Technical Support >> Reinforcing a Sloped Slab - Please Help!!
Mon, Mar 17, 2008 at 11:20:50 AM | Reinforcing a Sloped Slab - Please Help!!
rcholodnuik
I've created a concrete slab in a project and I have added slope to this slab by highlighting it and selecting the modify sub element tool and assigning an elevation to the points in which I needed sloping.  After the slab was created, I used the sketch area reinforcement tool for adding rebar to this slab.  When I hit finish sketch and view the slab in section I see that the reinfocing does not follow the slope of the slab.  Does anyone know why this is?  Does it have anything to do with how I created the slope in the slab?
 I have attached the file so you can view what I am explaining.
Thanks
Thu, Oct 1, 2009 at 5:43:31 PM | Reinforcing a Sloped Slab - Please Help!!
LisetteTerry
LisetteTerry Avatar
I am having the exact same issue.  How do I tell the reinforcing to have a start and finish elevation so it can slope with my slabs?  Thank you.
Life is not always linear...
sloped foundation slab to flat slab join
Mon, Mar 25, 2013 at 8:01:59 AM
sloped slab edge
Mon, Mar 22, 2010 at 7:16:26 AM
Test Labels with psuedo dimension lines
Tue, Sep 20, 2005 at 9:45:16 PM
Creating drop panels to the underside of a sloped floor slab
Fri, Feb 12, 2016 at 9:41:01 AM
can I model a rebar inside a model slab
Thu, Jan 10, 2013 at 12:29:27 PM
Page generation time: 0.6631
