78 Users Online (77 Members):
Forums >> Revit Building >> Technical Support >> Length Parameter
18 Posts No Rating |
Does anywone know how I can add a length parameter to a beam created with the complex template. The length wont appear in the material TO and when I try to add a parameter it wont create the element. ANy thought/suggestions? I have atached the family thanks
Place a reference plane in the family to end your extrusion, name it, dimension it and change the dimension to an instance parameter. You will have to change the extrusion properties to use this reference plane. It would be helpful if you read up on family development in your REVIT manual.
THANKS WWHub, I'll give it a go
Can a Yes/No Parameter control a Length Parameter? |
Thu, Mar 22, 2012 at 12:17:27 AM
'Inconsistent units" error in parameter formula; length vs integer |
Fri, Dec 13, 2013 at 10:37:04 PM
-ve value for a length parameter |
Thu, Dec 2, 2010 at 12:14:32 AM
Creating a Beam Family Where Each Type has a Determined Length |
Wed, Aug 31, 2016 at 11:55:27 AM
11
Family Instance Parameter Dimension Help |
Wed, Apr 10, 2013 at 5:22:09 PM
Members: | 2017196 | Objects: | 22947 | Forum Posts: | 152212 | Job Listings: | 3 |
