107 Users Online (105 Members): Show Users Online - Most ever was 626 - Mon, Jan 12, 2015 at 2:00:18 PM
Forums >> Revit Building >> Technical Support >> Room Bounding - Room area changes, then changes back for no reason!
Fri, Mar 14, 2008 at 1:22:06 PM | Room Bounding - Room area changes, then changes back for no reason!
Becca
I'm having a problem with re-associating my rooms.  We have to include some interior partitions within certain groups of areas as a part of the total area count:
This worked by A. making the walls non-room bounding, and then B. using the Room Separation tool to specify distinct areas.
But I came back to the project a couple of hours later, and the walls are now room bounding, but the check-box in the properties is not checked!  This is a weird bug, and it's disrupting my area calculations.  Please advise!
Wed, Apr 28, 2010 at 4:13:08 PM | Room Bounding - Room area changes, then changes back for no reason!
dguich
We are having the same problems. Is there a solution? Has anyone addressed this to Autodesk and had any responses from them? This problem is disrupting our BOMA area calculations.
Thanks.
Wed, Apr 28, 2010 at 4:48:29 PM | Room Bounding - Room area changes, then changes back for no reason!
dguich
Select your walls that are bounding the room and check the properties. In the element propert dialog box check if walls are "room bounding". This should resolve the issues you are having.
Wed, Apr 28, 2010 at 6:22:41 PM | Room Bounding - Room area changes, then changes back for no reason!
TomDorner
4.5 Stars: 25 Votes
Be sure that everyone here understands that "rooms" and "areas" in Revit are not related.  Rooms are 3D objects that fill spaces bounded by walls set to room bounding or defined by room seperation lines.
 Areas are 2D objects that occur in specific types of area plans.  Area boundries are placed into an area plan via rules that respond to Revit's BOMA area type matrix, or you place the area boundries yourself by drawing them.
A walls property of room bounding cannot disrupt area calculations performed in an area plan.  Areas know nothing about rooms and rooms know nothing about areas.
HTH
Edited on: Wed, Apr 28, 2010 at 6:24:27 PM
Tom
www.reviteer.com   http://twitter.com/Reviteer
room bounding problem
Fri, Jul 28, 2017 at 4:03:51 AM
13
Rooms!!!
Wed, Dec 12, 2012 at 12:24:14 PM
Room bounding blackhole
Fri, Aug 19, 2011 at 12:08:31 PM
BIG curtain wall room bounding problem!!
Mon, Dec 14, 2009 at 9:31:32 AM
Ceiling not bounding room
Wed, Oct 6, 2010 at 4:01:36 PM
Page generation time: 1.3587
