108 Users Online (107 Members):
Forums >> Revit Building >> Technical Support >> Detail & Section Tags
2 Posts No Rating |
I have sections and details referenced to drafting views and I want to modify the tag. Specifically, I want to be able to edit the drawing number and keep it inside the bubble. When I try to modify it, it places the drawing number in the location of the default SIM label. Is there a way to remove the auto drawing number for editing? Also, on section tags, is there a way to make them display the arrows to match all the others? Using Revit Architecture 2008
Look in the help under "Section" ... "Creating a Section Head Family"
additional detail tags |
Thu, Apr 19, 2012 at 3:27:31 PM
Section tag font not changing in "side" section tags |
Thu, May 22, 2008 at 9:21:54 AM
plan detail callout in section |
Fri, Mar 29, 2013 at 12:48:11 PM
14
Using 2d group for Wall section, section details called out from wall section? |
Fri, Oct 9, 2015 at 10:50:56 AM
Two Detail Tags with Same reference Sht & Dwg |
Fri, May 23, 2008 at 10:23:03 AM
Members: | 2057892 | Objects: | 23076 | Forum Posts: | 152250 | Job Listings: | 3 |
