44 Users Online (43 Members): Show Users Online - Most ever was 626 - Mon, Jan 12, 2015 at 2:00:17 PM
Forums >> Revit Building >> Technical Support >> Showing Underlay Plan
Tue, Mar 15, 2005 at 1:15:06 PM | Showing Underlay Plan
Osir
I have imported aplan from AutoCAD to work from. However, I find that once I draw walls, I can no longer see the plan to put in windows. I tried adjusting the default Object Style for Walls, but am finding that most of the wall types were manually set to show a solid fill poche pattern (oops). Anyone know a quick & easy way to make all the walls transparent but still manipulatable? Here's a good reason to define materials by object style!
-IOeser
Mon, Mar 21, 2005 at 7:11:55 AM | RE: Showing Underlay Plan
saumya
view in line wireframe mode,rather than shaded voew mode.
Mon, Mar 21, 2005 at 11:08:59 PM | RE: Showing Underlay Plan
Mr Spot
Mr Spot Avatar
4.5 Stars: 93 Votes
Select the DWG and look at the top of the screen, there should be a pull down that reads Background... Change it to foreground, this will put the dwg on top of your model elements so you can read it... This is providing you are using version 7.0 and have imported using current view only... HTH.
misguided underlay
Tue, Feb 19, 2013 at 8:14:29 AM
Underlay not showing
Mon, May 12, 2014 at 3:57:09 PM
Show dimensions of the underlay
Thu, Jun 8, 2017 at 7:52:18 AM
REVIT 2015 - Underlay: EXPORT?
Tue, Aug 5, 2014 at 2:54:54 PM
wrong underlay showing
Mon, Jan 27, 2014 at 1:29:57 PM
Page generation time: 0.7412
