80 Users Online (79 Members): Show Users Online - Most ever was 626 - Mon, Jan 12, 2015 at 2:00:18 PM
Forums >> Revit Systems >> Technical Support >> Rendering: Ground Plane stuck
Thu, Mar 13, 2008 at 11:25:59 AM | Rendering: Ground Plane stuck
RandallRands
I don't know when Acurender was deleted from Revit, but this is what I use in my Revit 7.0. I have been wanting to render views and walkthroughs - but can't get my ground plane to change height, or turn off. I click the button to deselect ground plane but when I render -there it is. When I go into the groundplane menu and lower it 2' or raise it to 100' so it will be out of the view, there it is again in the usual spot at 0.0 when I try to render. I have learned to work around this by placing all items in my new projects above the ground plane. It is the old projects  that I want to include in my portfolio, and need to get rid of this groundplane. Has anyone had this problem before?
Rendering - Changing Ht of Ground plane does not 'stick'
Thu, Mar 10, 2005 at 4:35:09 PM
Rendering Ground Plane
Wed, Oct 4, 2006 at 1:00:20 PM
Ground Plane in Rendering
Tue, Feb 22, 2005 at 2:25:55 PM
Rendering Ground Planes showing up when i dont want them to
Wed, May 10, 2006 at 7:14:44 AM
ground plane rendering
Thu, Aug 16, 2012 at 11:54:39 AM
Page generation time: 1.3078
