61 Users Online (58 Members): Show Users Online - Most ever was 626 - Mon, Jan 12, 2015 at 2:00:17 PM
Forums >> Revit Building >> Technical Support >> Door Cill
Thu, Mar 13, 2008 at 2:31:57 AM | Door Cill
2005Mark
3.5 Stars: 2 Votes
I am using Revit 2008. I want to flip an external door so that the door opens out. When I do this the cill flips to inside. How can I lock the cill to outside as well as the door.
regards
Mark
Thu, Mar 13, 2008 at 7:29:26 AM | Door Cill
coreed
coreed Avatar
4 Stars: 16 Votes
You can check in the properties of the door and see if it was designed with a sill for both sides of the wall that can be turned on and off as desired. If not, you have to edit or duplicate the family yourself to create one that fits your need.
best regards,
coreed,aia
bmpArchitects,Inc.
Long Live Revit
WINDOW CILL FAMILY PROBLEM
Wed, Apr 11, 2018 at 12:44:13 AM
Precast Stone Window Cill
Mon, Dec 16, 2013 at 7:42:36 AM
Problems with extrusions attached to moving work planes
Wed, Aug 25, 2010 at 6:39:45 AM
Door Schedule
Fri, Aug 17, 2012 at 7:07:50 AM
Door parameters not scheduling or tagging in double door.
Mon, Sep 26, 2011 at 3:29:50 PM
Page generation time: 0.5109
