60 Users Online (58 Members):
Forums >> Revit Building >> Technical Support >> need help with elevations
11 Posts No Rating |
hi, ive finished my plans on my project and wanted to have a look at my elevations as i wanted to add signs and text to my building, but the elevations look like sections why is this happening? is there a setting that i have missed or is this normal for revit 2008? thanks, kunal
![Hogmodo Avatar](user_avatar/1029.jpg)
![3.5 Stars: 6 Votes](/images/stars_3.5.gif) |
Single click on the elevation triangle on your plan. That is the one aimed at the building. You should see the blue line showing where the elevation is "cut". Yours is probably into your building which creates a section/elevation. Click and drag the line back to whereever you want the elevation to start.
thanks, mate it worked fine kunal
Problem with Interior elevations |
Fri, Feb 13, 2015 at 1:51:29 PM
how to add elevations to door & window schedules |
Tue, Oct 30, 2007 at 11:59:24 AM
Getting door elevations |
Thu, Nov 21, 2013 at 6:12:08 PM
12
Editing Font on titleblocks below elevations/plans on sheets? |
Tue, May 22, 2007 at 4:46:36 PM
interior elevations |
Sat, May 2, 2009 at 11:28:06 AM
Members: | 2022335 | Objects: | 22974 | Forum Posts: | 152200 | Job Listings: | 3 |
