54 Users Online (53 Members): Show Users Online - Most ever was 626 - Mon, Jan 12, 2015 at 2:00:17 PM
Forums >> Revit Building >> Technical Support >> LOOKING FOR small CORNER SINK
Tue, Mar 11, 2008 at 9:53:07 AM | LOOKING FOR small CORNER SINK
elvis
Hi all. i am looking for a small corner sink,
for a toilet area, to position it in a wall corner?
some one has one?
 grtzE
Tue, Mar 11, 2008 at 12:06:23 PM | LOOKING FOR small CORNER SINK
3.5 Stars: 395 Votes
Here is one
Tue, Mar 11, 2008 at 12:53:24 PM | LOOKING FOR small CORNER SINK
elvis
Thnxs,
E
Wed, Feb 2, 2011 at 12:53:16 PM | LOOKING FOR small CORNER SINK
trufla
I don't know why but it doesn't work for me Sad
Wed, Feb 2, 2011 at 1:00:31 PM | LOOKING FOR small CORNER SINK
Wall based family ...If you can open the file, then it will work fopr you.
Tue, Feb 14, 2017 at 3:04:40 PM | LOOKING FOR small CORNER SINK
jmhmoniz
Doesn't work for me either, I can open the family but when I insert it into the model I get an error "Can't make type "33988_Corner_Sink"." However I deleted the locked 0'-0" dimension off the wall and then it works, so if you are looking for a quick fix then try that.
Edited on: Tue, Feb 14, 2017 at 3:14:34 PM
Thu, Feb 8, 2018 at 7:33:12 AM | LOOKING FOR small CORNER SINK
placidofreites
jmhmoniz How do you remove that dimension?
Thu, Feb 8, 2018 at 3:03:07 PM | LOOKING FOR small CORNER SINK
jmhmoniz
Open the family. Go to the Ref. Level view. Select the dimension that is called "Off the Wall = 0'-0"" and hit delete.
Thu, Feb 8, 2018 at 3:25:38 PM | LOOKING FOR small CORNER SINK
placidofreites
Thank you!
Counter Top w Sink in Revit 2013
Mon, Mar 11, 2013 at 5:36:29 PM
Cutting countertop for sink
Tue, Apr 15, 2014 at 5:21:32 PM
Suggestion required - Sink aperture adjustment
Thu, Nov 19, 2009 at 9:36:36 PM
Looking for a farm sink .rfa
Tue, Oct 1, 2013 at 3:58:07 PM
Modelling Sink - Problem
Tue, Mar 21, 2017 at 5:00:16 PM
Page generation time: 0.3611
