82 Users Online (81 Members): Show Users Online - Most ever was 626 - Mon, Jan 12, 2015 at 2:00:17 PM
Forums >> Revit Building >> Technical Support >> Text in multiple columns
Mon, Mar 10, 2008 at 9:52:07 PM | Text in multiple columns
Oak3s
Revit 2008
 Currently I am copying from a word document and pasting that into revit when using the text tool. That creates one really long column. How do I make it multiple columns? Thanks.
Tue, Mar 11, 2008 at 5:51:16 PM | Text in multiple columns
jarosa
jarosa Avatar
4 Stars: 5 Votes
You should be able to stretch the text box and that may help. Unfortunately Revit isn't strong as a text editor. Otherwise, here's a thread i found on the subject.
http://www.revitcity.com/forums.php?action=viewthread&thread_id=3334
good luck
Tue, Mar 11, 2008 at 6:58:51 PM | Text in multiple columns
Oak3s
Thank you Jarosa for the reply. This is disapointing. What a powerful program. Hard to believe it is missing something much needed. I have hopes for 2009.
Wed, Mar 12, 2008 at 2:56:08 PM | Text in multiple columns
twhisker
2 Stars: 4 Votes
Another way to create text into columms is to create a generic schedule.
1) View-New-Schedule
2) check the box "Show categories from all discplines"
3) select a category you may never use (we use air terminal)
4)select the "schedule keys" radio button and name it what your first columm would be.
5) then add additional parameters for each columm.
We use this for abbreviation list, code list, Sheet notes, dummy consultant sheet index ---  basicaly anything you want to have in multiple columms and neatly tabbed.  Unfortunately you will have to manually type in the information.  But if this is used for multiple projects, you can then save it in your project template.  the abbreviation list took 2 hours but now its formatted and adjustable to fit any space.  Good luck!
Revit Architecture 2010
Wed, Mar 12, 2008 at 3:39:26 PM | Text in multiple columns
Oak3s
Thank you for the suggestion.
columns with multiple parts.
Mon, Jan 19, 2009 at 9:38:37 PM
adding text to multiple views simultaneously
Wed, Feb 24, 2010 at 7:30:46 PM
columns with multiple girts
Wed, Nov 23, 2011 at 10:29:58 AM
Schedule Headings over multiple (but not all) columns
Tue, Feb 1, 2011 at 8:24:41 AM
text in Graphical schedule columns to far from lines
Thu, Dec 16, 2010 at 12:58:21 PM
Page generation time: 0.9637
