70 Users Online (69 Members): Show Users Online - Most ever was 626 - Mon, Jan 12, 2015 at 2:00:18 PM
Forums >> Revit Structure >> Technical Support >> Hatching a conc wall
Fri, Mar 7, 2008 at 10:08:59 AM | Hatching a conc wall
AlexDring
1 Stars: 1 Votes
If i have a conc wall that is getting cut threw how do i tell revit to hatch it?  I have a concrete shearwall that is continous to the roof, but on my 1st floor plan, or any plans, it is not hatched indicating that its continous.
Fri, Mar 7, 2008 at 11:40:59 AM | Hatching a conc wall
TJKENNEDY
3 Stars: 2 Votes
There are several things to check. In the element properties, check the "Coarse Scale Fill Pattern", it should be set to whatever concrete hatch you are using. Under the wall construction, your material need to be some kind of concrete, and the material cut pattern should be your concrete hatch.
Fri, Mar 7, 2008 at 11:49:55 AM | Hatching a conc wall
AlexDring
1 Stars: 1 Votes
its all set to concrete hatch.  must be my view depth.
Hatching
Wed, Nov 7, 2012 at 11:02:11 AM
hatching/visibility issue
Wed, Mar 26, 2008 at 3:10:45 PM
Topography and hatching in section / elevation
Sat, Sep 27, 2008 at 7:55:42 PM
Align Fire Wall Hatching in Wall
Tue, Jul 3, 2012 at 7:07:44 AM
HATCHING 2008
Fri, Jun 22, 2007 at 11:19:08 AM
Page generation time: 2.3347
