24 Users Online (23 Members): Show Users Online - Most ever was 626 - Mon, Jan 12, 2015 at 2:00:17 PM
Forums >> Community >> Newbies >> foundation footings
Fri, Mar 7, 2008 at 9:27:03 AM | foundation footings
ngc5128
I need to move the footing of our foundation down, but I can't find where to edit it. It's not in the properties. HELP!
Fri, Mar 7, 2008 at 5:00:17 PM | foundation footings
dgcad
dgcad Avatar
3.5 Stars: 36 Votes
Footings are attached to the bottom of the wall. They have thickness and width but the elevation is controlled by the bootom of the wall itself. You should probably have a look at the REVIT CADclip tutorials at www.CADclips.com
Tue, Jul 22, 2008 at 1:48:21 PM | foundation footings
Thread Post Kudo! #3
Elyse717
or, instead of paying for unnecessary tutorials, someone could just tell you. have you tried creating a new level for the wall height? if you don't want to make a new level, right click the wall, go to element properties, and adjust the offset (this will be a negative number since you are trying to move it down) of the base constraint for the wall. the footing will follow it.
also, if you google keywords like "footing" with "revit architecture 2008" or "2009," you should be able to find plenty of blogs addressing beginning issues. many of the people running the blogs are Revit consultants for firms, so they break down the steps better than some tutorials.
Tue, Jul 22, 2008 at 2:14:31 PM | foundation footings
4 Stars: 201 Votes
ELYSE, you have my bless....
Footings for Slab Foundation
Tue, Oct 30, 2007 at 7:05:08 AM
dashed line for foundation footings?
Thu, Feb 9, 2006 at 4:04:06 PM
Changing Linetypes in Foundation Plan
Thu, Mar 18, 2010 at 7:18:01 AM
Foundation Schedule - no footing thickness field - help!
Fri, Dec 2, 2011 at 10:24:44 AM
12
Wall Footings and Foundation extrusions
Wed, Jun 8, 2016 at 7:55:54 AM
Page generation time: 0.2461
