71 Users Online (69 Members): Show Users Online - Most ever was 626 - Mon, Jan 12, 2015 at 2:00:18 PM
Forums >> Revit Building >> Technical Support >> Putting tile on the wall. under cabinets. On Revit 2008
Fri, Mar 7, 2008 at 2:13:46 AM | Putting tile on the wall. under cabinets. On Revit 2008
YouiGetWhatYouGive
Please let me know how to do it.  Thanks
Fri, Mar 7, 2008 at 8:54:53 AM | Putting tile on the wall. under cabinets. On Revit 2008
You have several options depending on your project and needs.
  1. Simple put a hatch in your elevation.  Only a 2d solution & no parametrics.  No output to take-offs.
  2. Edit face on the wall and pour on a new finish.  This could be a 2d or 3d solution depending on the pattern you apply.  -  No output to  take-offs.
  3. You could add a thin wall to the face of your wall that is just this tile material.  Fully parametric (height - starting - ending elevation).  Can be 2d/3d depending on the assigned material.  This will show up in quantities.
Floor tile patters show under cabinets
Sun, Mar 25, 2007 at 11:08:04 PM
Tile Backsplash on kitchen wall
Wed, Feb 29, 2012 at 6:13:30 AM
Creating furr downs above cabinets...
Fri, Jul 13, 2012 at 8:36:38 AM
How do I add crown molding to wall cabinets?
Mon, Sep 22, 2014 at 7:13:44 AM
Walls - Incorrect tile shown - Revit 2011
Tue, Dec 14, 2010 at 4:05:34 PM
Page generation time: 3.0999
