78 Users Online (76 Members): Show Users Online - Most ever was 626 - Mon, Jan 12, 2015 at 2:00:18 PM
Forums >> Revit Building >> Technical Support >> Slab Foundation Questions
Thu, Mar 6, 2008 at 4:38:36 PM | Slab Foundation Questions
rcobbjr
3.5 Stars: 3 Votes
I am using Revit 2008. I am trying to create a foundation plan for a building. I want to "hide" the concrete slab floor throughout the structure in the foundation plan. I want to show the footings and the foundation wall. How do I "not show" the slab without disabling the Structural Foundation model category?.
 Question #2
I have a structure that is on a slab foundation. The garage floor is 4" lower than the slab for the rest of the house. There is a load bearing wall that is separating the garage and the utility/laundry room. There has to be a foundation wall and footing under the load bearing wall between the garage and utility room. Since there is a 4" difference between the garage floor and the floor of the utility room, can someone "sketch" me a section drawing of how the foundation wall is that is supporting the garage floor, the load bearing wall, and the slab floor in the utility room?
Thu, Mar 6, 2008 at 4:49:46 PM | Slab Foundation Questions
To hide any element in any view in 2008, just right click on it and hide in view.
Thu, Mar 6, 2008 at 8:38:16 PM | Slab Foundation Questions
rcobbjr
3.5 Stars: 3 Votes
Thanks for the info. How do you bring them back once they are hidden?
Fri, Mar 7, 2008 at 10:56:29 AM | Slab Foundation Questions
Come on now ... please use your  H E L P .......  "hide"  all is revealed.  Using that for simple questions is easy than asking here....
Footings for Slab Foundation
Tue, Oct 30, 2007 at 7:05:09 AM
sloped foundation slab to flat slab join
Mon, Mar 25, 2013 at 8:02:00 AM
Mid slab foundation thickening
Tue, Jul 31, 2012 at 7:58:12 AM
Slab in foundation plan
Wed, Dec 21, 2005 at 5:10:29 PM
Shared Parameters as part of a Foundation Slab
Tue, Jun 7, 2011 at 5:37:48 AM
Page generation time: 1.8525
