84 Users Online (83 Members):
Forums >> Revit Building >> Technical Support >> I put an image file behind an elevation but it doesn't print properly...
1 Posts No Rating |
I'm trying to create simple flat coloured 2D elevations (i.e. 'shading with edges' option) on a sheet with an image file behind (in this case a jpg of the sky). It looks ok on the sheet but when I come to print it, it shows big white triangles on th page. It can't be the printer's fault because this problem shows in print preview. It looks as if the software is trying to cast a shadow on the background but is doing it with a ray of white.
(I set up the elevations on the sheet and then imported the image onto the sheet - it automatically put itself behind the model)
Any ideas to get around this? + Is it possible to place an image infront of a 2D model on the sheet - e.g. a company logo?
2 Posts No Rating |
Hey,
The only thing I can can think of is it may be your elevation annotations. Did you uncheck your annotations in the visability settings. Simply right click your elevations (remember to do each elevation) and select settings. Your may also right click on the triangle icons and select hide annotation.
hope that helps,
Patrick
HOW DO I PRINT MY JPEG IMAGE? |
Mon, Jun 4, 2012 at 7:09:49 AM
putting a print on glass |
Fri, Apr 23, 2010 at 6:13:19 AM
Print Order |
Wed, Nov 21, 2012 at 2:17:41 PM
Bitmap doesn't print |
Mon, Oct 25, 2010 at 4:29:23 PM
ELEVATION TAG CAN'T PRINT |
Thu, Nov 9, 2006 at 12:21:50 PM
Members: | 2017148 | Objects: | 22947 | Forum Posts: | 152211 | Job Listings: | 3 |
