49 Users Online (48 Members): Show Users Online - Most ever was 626 - Mon, Jan 12, 2015 at 2:00:17 PM
Forums >> Revit Building >> Technical Support >> Master Model, File Referencing?
Thu, Mar 6, 2008 at 8:07:54 AM | Master Model, File Referencing?
mflure
Greetings all,
I appologies if this question has already been posted.  I found some that are similar but doesn't quite cover all of what I'm tryihng to accomplish.
First a bit of information:  I have a 5 story office complex that I'm curently working on modeling out the shell.  There are about 12 tenants in the building and I would like to be able to create a master model that I can have our commercial management and leasing departments have access to when needed. This will be my first attempt at a project of this size and type, and it will also be the first time I will reference another revit file.
So now to the questions:  What tips, issues and/or problems should I be aware of?  Is it just as simple as to create a file and reference the shell, and each separate tenant files, to create one master file?  Is there a way to create a master file with a similar command like BIND in autocad, this is so I can keep a history of the entire building from change to change?
Thanks,
Michael
Thu, Mar 6, 2008 at 8:24:15 AM | Master Model, File Referencing?
NKramer
4 Stars: 9 Votes
You can copy/ monitor the files together and then track changes that way. I dont know if the track changes works with linked files.
There is a good post from brettgoodchild on this post http://www.revitcity.com/forums.php?action=viewthread&thread_id=10146
You might want to do some more searches/ research on copy monitor.
HTH
Nick
Mon, Mar 10, 2008 at 7:35:25 AM | Master Model, File Referencing?
mflure
Nick,
 Thanks for the information.  That gives me a starting point.
 Mike
Mon, Mar 10, 2008 at 8:49:20 AM | Master Model, File Referencing?
You can even set up a master project directory with all of the drawings of the linked files listed (name - number ...).  You would still have to access the individual files to see the drawings.  You could sort those drawings by project/name / number.
looking for a keynote master file workaround
Fri, Apr 3, 2009 at 6:57:06 PM
Splitting Master Model into separate Interiors and Docs Models
Wed, Aug 21, 2013 at 7:24:50 AM
File size issues: Linking multiple Buildings into a Master Site File
Tue, Mar 8, 2011 at 9:52:00 PM
Master model
Mon, Mar 9, 2009 at 12:59:36 PM
Revit Keynote file - National Master Spec
Thu, May 19, 2016 at 11:23:40 AM
Page generation time: 1.1943
