70 Users Online (68 Members): Show Users Online - Most ever was 626 - Mon, Jan 12, 2015 at 2:00:17 PM
Forums >> Revit Structure >> Technical Support >> Typical Detail Library
Thu, Mar 6, 2008 at 8:03:10 AM | Typical Detail Library
iksnawi
I am having problems saving typical details to a library and are they suposed to be saved as a view in order to use them on different projects.
Thu, Mar 6, 2008 at 1:31:52 PM | Typical Detail Library
hhwse
If they are "drafting views" use "save to Library / save views"  if it is a model based detail you will need to freeze it using the freeze drawing extension from this link.  http://www.extensions4revit.com/
Fri, Mar 7, 2008 at 7:54:49 AM | Typical Detail Library
Bm3875
Bm3875 Avatar
4 Stars: 7 Votes
I have heard of this before, has anyone tried it or had any luck using it in Revit Architecture 2008?
cad.web.print
Fri, Mar 7, 2008 at 9:44:59 AM | Typical Detail Library
hhwse
I have used several of the extensions and they work great.  With the "freeze drawing" you can make a 2D drafting view of a 3D section and make modificatons as needed or export to a typical library.
Custom Library - Typical Details
Fri, Jun 24, 2011 at 1:10:55 PM
Typical Detail sheets on my first revit project
Mon, Feb 8, 2010 at 9:22:07 AM
Family- Typical Detail
Fri, Sep 2, 2005 at 12:21:53 PM
Typical Details
Mon, Mar 26, 2012 at 4:55:56 PM
Detail library
Sat, Aug 19, 2017 at 11:00:10 AM
Page generation time: 1.3637
