29 Users Online (28 Members): Show Users Online - Most ever was 626 - Mon, Jan 12, 2015 at 2:00:18 PM
Forums >> Revit Building >> Technical Support >> linework tool
Thu, Mar 6, 2008 at 7:09:48 AM | linework tool
thankyoufrankgehry
1 Stars: 1 Votes
Hi.  I am wondering if there is a way to select all instances of a component and with using the linework tool show it as a dashed object, because it is something not being provided in the contract.  BTW, I am using Revit Building 9 and the object I am writing about happens to be a keyboard/monitor set up (It is a 3d component).  Thanks in advance.  No one in my office seems to have a clue.
Thu, Mar 6, 2008 at 8:35:19 AM | linework tool
JAMESHGRIMES
JAMESHGRIMES Avatar
4.5 Stars: 10 Votes
Its has been a while since I used 9.1 but I think you can hit tab while you are hovering over a line and it will select all lines of an object.
Thu, Mar 6, 2008 at 9:14:19 AM | linework tool
thankyoufrankgehry
1 Stars: 1 Votes
I know that I can tab select to get the whole object, but I am trying to select all of the component copies (I have, like, over a hundred keyboards that I am trying to switch the line work of).
Thu, Mar 6, 2008 at 9:23:07 AM | linework tool
JAMESHGRIMES
JAMESHGRIMES Avatar
4.5 Stars: 10 Votes
Oh I see. I'm not sure if there is an easier way. You might look into filters. I believe you can set up a filter that will recognize a particular family and then apply that filter in the Visibility Graphics dialog. This should allow you to turn all objects the filter picks up to dashed line type.
Thu, Mar 6, 2008 at 10:41:50 AM | linework tool
Here are a couple of options you could try.
  1. Redefine the family.  Turn off the 3d representation in 2d views and use hidden symbollic lines.
  2. Redifine the family and put it in a category that you halftone in your views.  Not hidden lines but obviously ghosted elements.
Thu, Mar 6, 2008 at 12:19:35 PM | linework tool
JAMESHGRIMES
JAMESHGRIMES Avatar
4.5 Stars: 10 Votes
Those are both excellent solutions. Don't know why didn't I think of that. Thanks WWHub.
Linework tool issue
Mon, Sep 26, 2011 at 3:20:45 PM
Linework Tool (LW)
Thu, Mar 11, 2010 at 4:34:31 PM
linework tool - showing through?
Thu, Nov 16, 2006 at 4:20:56 PM
Linework Tool
Mon, Jul 28, 2014 at 8:42:23 AM
linework tool - original showing up next time I open revit project
Fri, Aug 8, 2014 at 2:18:22 PM
Page generation time: 2.2263
