126 Users Online (124 Members): Show Users Online - Most ever was 626 - Mon, Jan 12, 2015 at 2:00:17 PM
Forums >> Revit Structure >> Technical Support >> sloping steel roof deck problem
Wed, Mar 5, 2008 at 5:30:56 PM | sloping steel roof deck problem
hhwse
I am working on a typical warehouse type building with 1.5” metal deck sloped at ¼:12.  It appears that if I use an architectural “roof” I cannot get the steel deck profile and the deck span tags to work.  If I make my “roof” out of a structural floor with a slope, all of that works just great.  The problem is that all I can get from the spot elevations is the top of deck elevation because floors insert based on the top surface.  I want spot elevations to be top of steel or bottom of deck.  Is there any way to set up a slab so its insert is the bottom of core?
Wed, Mar 5, 2008 at 5:55:12 PM | sloping steel roof deck problem
hhwse
I think what i am looking for is some way to get spot elevations for the bottom of the slab.  is this possible?
slope metal roof deck
Thu, Jul 21, 2011 at 9:40:39 AM
Sloping Steel Column
Sat, Aug 21, 2010 at 6:14:05 AM
Sloping 5/14" metal deck roof to sit on sloping OWSJ structure
Wed, Dec 3, 2014 at 8:50:16 AM
Exposed Structural Floor Ceiling Plan
Thu, Mar 21, 2013 at 8:30:25 AM
Roof to follow sloped structural steel
Wed, Sep 22, 2010 at 4:11:16 AM
Page generation time: 0.9341
