39 Users Online (38 Members): Show Users Online - Most ever was 626 - Mon, Jan 12, 2015 at 2:00:18 PM
Forums >> Revit Building >> Technical Support >> Roof overhang not following 2" Facia Square cut
Wed, Mar 5, 2008 at 10:22:19 AM | Roof overhang not following 2" Facia Square cut
lorne17
lorne17 Avatar
3.5 Stars: 7 Votes
Hello,
I'm creating a roof and the facia is not getting cut accurately on my overhang.  I set the roof properties to be 2" facia with a two cut sqare roof.  Well it doesn't do that on the overhang, it stays at it's 7 3/4" roof facia with plumb cut.
Anyone know how to fix this?  Refer to pictures below.  Thanks
Denver, CO
Revit Architecture
Wed, Mar 5, 2008 at 10:33:06 AM | Roof overhang not following 2" Facia Square cut
lorne17
lorne17 Avatar
3.5 Stars: 7 Votes
Does it matter if I use teh Pick Walls tool for my 3' overhangs then had to draw in the lines with no "defines Slope" for my 5' overhang?  Because if I don't use the Pick Walls tool, My plate height is screwed up.  The roof doesn't get built from the Walls plate height.  Revit makes the lowest part of my roof at the plate height...so therefore the roof is sitting too high.
Denver, CO
Revit Architecture
"Two Cut - Square" Rafter Cut won't appear with Roof by Extrusion.
Fri, Jun 2, 2017 at 9:49:10 PM
Why is my roof doing this?!?
Tue, Nov 27, 2007 at 8:59:54 AM
Modify Roof Facia
Wed, Feb 28, 2007 at 2:22:40 PM
Can't make a Two Cut - Square rafter cut on a roof
Fri, Jan 14, 2011 at 6:20:31 PM
can't adjust roof overhang
Mon, Feb 16, 2009 at 12:13:00 PM
Page generation time: 2.7820
