40 Users Online (37 Members): Show Users Online - Most ever was 626 - Mon, Jan 12, 2015 at 2:00:18 PM
Forums >> Revit Building >> Technical Support >> Linked model not staying linked
Tue, Mar 4, 2008 at 2:35:48 PM | Linked model not staying linked
InVision
I have the MEP model linked into my architectural model but every time I save to central it unloads the linked file and I have to reload it manually to get it back.  What could be causing this?
Fri, Apr 25, 2008 at 3:15:07 AM | Linked model not staying linked
mgr2820
2 Stars: 2 Votes
If your MEP file is a detached central file from a consultant- you need to open it as a detached file and save under a new name. Then use this file to link. Copied central files act like local files- always searching for the central. This seems to create an issue with linking. Detaching and renaming always works for me.
Not able to place room copied from linked model
Wed, Mar 18, 2015 at 8:10:38 AM
Lineweights in linked model
Wed, Nov 19, 2014 at 8:06:45 AM
Can't select the linked model
Mon, Aug 4, 2014 at 1:06:27 PM
Linked Model Showing In 3D View Only
Tue, Aug 5, 2014 at 1:11:43 PM
Linked Revit Model Sheets
Fri, Apr 5, 2013 at 12:04:29 PM
Page generation time: 0.9641
