75 Users Online (74 Members):
Forums >> Revit Building >> Technical Support >> Curved wall in plan and elevation
2 Posts No Rating |
Can someone tell me how to make a wall that is curved in plan and in elevation?
THis one was an easy one to find in the help file in Revit by searching for curved wall. But, since I am writing anyway, you can do one of two things: 1. Once in the WALL command, select one of the curve options on the options bar 2. Draw a curved line and select it after choosing the "pick lines" tool (white arrow) on the options bar. I find the latter helpful for more complicated curved walls with specific geometry. hth.
**Using Revit Architecture 2009, 2011, and 2012** |
2 Posts No Rating |
I know how to make the curved wall but in elevation it has a gothic arch on top. Does anyone know how to make this shape on a curved wall?
Option 1. If it is under a roof in the shape you want, simply attach it to the roof. Option 2. If no roof is above, select the wall in elevation view, then click the edit profile button on the options bar. the outline of the wall turns to magenta lines. you can add and delet them at will, but I would recommend only enough customization as necessary. Also, you'll need to double check the geometry if you stretch the wall after you edit the profile as it will effect it. hth
Im not sure you can edit the profile of a curved wall... But other options would include making an in-place family consisting of a void to cut the wall, else massing to free model the shape you want and apply your wall to the face. Hope this helps!
You are correct, you can not edit the profile of a curved wall. The in-place family or a roof would be your best bet.
Projected Curved Elevation (How to flatten a curved wall in elevation view) |
Fri, Feb 11, 2011 at 11:55:48 AM
Complex Curved Walls - please help |
Wed, Mar 25, 2009 at 5:26:10 PM
Modelling a curved curtain wall |
Thu, Aug 25, 2011 at 7:18:35 AM
True elevation for curved curtain wall |
Tue, Aug 26, 2008 at 8:13:27 AM
curved surface |
Tue, Nov 6, 2018 at 7:03:42 AM
Members: | 2057494 | Objects: | 23074 | Forum Posts: | 152250 | Job Listings: | 3 |
