56 Users Online (55 Members):
Forums >> Revit Building >> Technical Support >> Masking Region Fill Region Problem
![albertobalsalm Avatar](user_avatar/45977.jpg)
![3 Stars: 1 Votes](/images/stars_3.gif) |
Hi, My problem is this: In a plan view I have a Masking region with a Filled Region on top (the Masking Region and the Filled Region are different but overlap in some areas). In the view and on the sheet on the computer screen everything looks the way I want it to, but when I print it, the masking region ends up blocking the fill. I have double checked and made sure the masking region is sent to the back and the filled region is set to be the front in terms of order. Does anyone know what's going on? I saw a post here were someone said to just use a white filled region instead of a masking region. Is there another solution? By the way I am using Revit Arch. 2008. Thanks in advance. AB
45 Posts No Rating |
Hi Personally so far, I have only used one or the other never both on top of each other. Everytime I've used Filled Region is "masks" everything else behind it. Mask region I use just to hide unwanted entities. John
Thanks for responding. I ended up eliminating the mask region and just using two filled regions, only one region is transparent and the other if opaque. thanks again ab
How to I have a fill region or masking region and have my CAD import over it? |
Tue, Oct 20, 2015 at 1:09:06 PM
Masking region at section callout head. |
Tue, Jul 30, 2013 at 1:43:26 PM
3D CAD import Part and masking region |
Sun, Sep 14, 2014 at 2:36:26 PM
Masking region in roof plan |
Tue, Feb 24, 2009 at 3:14:03 PM
Masking Region doesn't seem to be masking |
Thu, Mar 17, 2016 at 10:59:36 AM
Members: | 2022332 | Objects: | 22974 | Forum Posts: | 152200 | Job Listings: | 3 |
