55 Users Online (54 Members): Show Users Online - Most ever was 626 - Mon, Jan 12, 2015 at 2:00:18 PM
Forums >> Revit Building >> Technical Support >> Need help with rendering!
Fri, Feb 29, 2008 at 10:26:39 PM | Need help with rendering!
Bota
Hey, I'm very new to Revit and I was introduced to it through an architectural class at school. I've managed to figure the basics out, however, I'm having trouble with my rendering. Every time I render, my patterns disappear and everything justs looks different than what it did before I rendered it. Am I doing something wrong regarding the material or what?
Thanks in advance! :D
Sat, Mar 1, 2008 at 1:49:19 PM | Need help with rendering!
mthurnauer
3 Stars: 2 Votes
It would be helpful if you could include some images to show what you are talking about, but I think it is that you need yo understand all of the different settings under the Materials.  Every object in your model has a material.  If none has been assigned it is just the Default material. For every material, there is ability to select the hatch pattern when the object is cut, a surface pattern I.E. lines representing bricks on an elevation.  You can set the basic color that the material will be when viewing the model in a shaded view.  Last, there is a field to select the Accurender material.  This will be an image map or procedural texture that is used when you render.
Mon, Mar 3, 2008 at 9:51:00 AM | Need help with rendering!
maranelloboy
3 Stars: 2 Votes
First thought is that you're trying to use a Surface Pattern to render instead of AccuRender textures.  To get a better idea of what's going on, we'll need to see some screen shots.
Mon, Mar 3, 2008 at 10:17:44 AM | Need help with rendering!
Bota
Yeah, I was trying to use the surface patterns. I just figured out that there were actual textures that give the appearance of materials! Ugh, but thank you for your assistance!
Realistic Rendering [ 1 2 ]
Thu, Aug 4, 2011 at 2:30:38 PM
25
2 Days Rendering...38% Complete 2009 Slow Rendering [ 1 2 ]
Wed, May 13, 2009 at 7:36:40 AM
22
09' Rendering Issue
Wed, Jun 3, 2009 at 4:22:52 PM
11
Going from Rendering in RA 2008 to Rendering in RA 2009
Mon, May 11, 2009 at 4:32:51 PM
Wed, Aug 10, 2016 at 10:47:18 PM
Page generation time: 0.3623
