56 Users Online (54 Members):
Forums >> Revit Building >> Technical Support >> 'PAD' slope
7 Posts No Rating |
So why is it that i can't apply a simple slope to a 'pad' object in the site menu bar? I need pad and not floor. Floor objects don't cut through topography. suggestions? I've reivewed the "complex slab" tutorial from eldados circa Nov. 18th 2005. However i hope 3 years of development by AutoDESK would have generated a simplier solution. thanks!
Hi, when you create a PAD it's just like a kind of "HOLE or BASE", there aren't no slope in there (for yet), if you need a slope in your topography site you must create them by "Toposurface" with elevation points.
7 Posts No Rating |
well thats tedious. Thanks Revit Team! I mean its not like no one ever has a subgrade pad with a slope on it. That never happens.
![Bm3875 Avatar](user_avatar/11826.jpg)
![4 Stars: 7 Votes](/images/stars_4.gif) |
You can create a SLAB from the STRUCTURAL MENU and apply slopes and dips and humps etc. to it, assign a site material to it and see if that works for you.
Brandon Pike | Owner/BIM Specialist ![Photo Photo](http://lh6.googleusercontent.com/public/ok5WJ0t5CtLgka59pVXypK1UASDfFJ1TjNHSqryv1AtWcj8vbAVywBZRY3NmIFEaZgwjvJMqj14VRNxJXlF6FGHgKldjMNEgWkf4UBWuuw6INS8v3sHaAuI4j_u6)
cad.web.print website: http://www.thinkdesign-studios.com blog: http://www.bimtionary.blogspot.com/ |
7 Posts No Rating |
I'll try the slab in the structural menu. does the topography cut around the 'slab' as it does the 'pad'? Thanks Typhoon
You welcome, you can create a "SLAB" and put slope in that, but, your topography can't cut around the slab, you must do what i tell you before, create a "PAD" around your model, then give them elevation, that's the way you can cut the site , maybe in the next RAC 2009 they resolve this situation...
7 Posts No Rating |
Sigh Thank Typhoon, will do.
Roof's wont slope :( |
Mon, Apr 2, 2007 at 5:34:05 PM
slopped pad |
Fri, Jun 23, 2006 at 9:42:32 AM
Stair stringer slope doesn't match riser slope? |
Fri, Aug 21, 2015 at 10:30:14 AM
pads and phases |
Mon, May 22, 2006 at 1:20:40 PM
''Visibility grafics'' and ''create parts'' problem when mak |
Fri, Mar 19, 2021 at 11:45:46 AM
Members: | 2022559 | Objects: | 22975 | Forum Posts: | 152203 | Job Listings: | 3 |
