22 Users Online (21 Members): Show Users Online - Most ever was 626 - Mon, Jan 12, 2015 at 2:00:17 PM
Forums >> Revit Structure >> Technical Support >> Need a little help...
Thu, Feb 28, 2008 at 12:01:51 AM | Need a little help...
vanostran
vanostran Avatar
3 Stars: 2 Votes
Hi,
I'm new to Revit. On my floor plan I can see trees and hidden lines from my site plan. How do I make these invisible on my floor plan?
 Also, on my second floor plan I can see the garage. How can I remove this from 2nd floor plan sheet?
 Sorry about such basic questions. I am really new to Revit. Thanks in advance.
 Vanostran
Thu, Feb 28, 2008 at 5:52:16 AM | Need a little help...
mthurnauer
3 Stars: 2 Votes
In the plan, type VG (Visibility/Graphics).  Scroll through the list until you see plantings and uncheck it.  For the second floor issue, are you seeing the roof over the garage?  You need to adjust your view range
Thu, Feb 28, 2008 at 9:26:46 AM | Need a little help...
Not sure how your project is setup but you might find a plan region in the area of your garage will help you control what you want to see there.  You can set that area up with its own view range.
Thu, Feb 28, 2008 at 10:21:05 AM | Need a little help...
AlexDring
1 Stars: 1 Votes
You can also click on the object you dont want to see, click the sunglasses and hide catergory or element.  On the floor plan, if you dont want to see the plan below, right click over the plan, click properties, and click the underlay and choose none.
I am pretty new, there might be faster ways.
Thu, Feb 28, 2008 at 10:15:48 PM | Need a little help...
vanostran
vanostran Avatar
3 Stars: 2 Votes
thanks everyone. Found my problem.
Jon
Page generation time: 0.1863
