Forums >> Revit Structure >> Technical Support >> changing text style in a grid bubble
3 Posts No Rating |
I am trying to change text style in a grid bubble, but in “type properties” box I can not find this parameter. Does anybody know how to do it? I do not want to change all of them in system family. I want to create new system family, say grid3/4. How can I do it? Thank you.
8 Posts No Rating |
Select the grid >Go to proerties >Go to Edit > note the name of the SYMBOL <eg Grid Head> close down the properties box. Now go to Annotations in th Project Browser & look for the SYMBOL <eg Grid Head> select it, right click, select edit. Now make the changes you need and save it back to the project. Best of luck John A
3 Posts No Rating |
thank you, John. it was great jump. i spend much more time, because i wanted many different stiles on one level. and i still do not understand, why i can not save new styles under family-grid as multiple types. every time i load new style, it creates new families. to be short, visibility is great, but filing is ugly.
8 Posts No Rating |
You can create as many different style grid markers as you like & then change them by selecting the different style under SYMBOL John A
Column grid text too wide to fit in bubble |
Thu, Jul 1, 2010 at 8:32:06 AM
3d model text in grid bubble |
Mon, Apr 27, 2015 at 11:57:55 AM
Grid Lines - Instance based text in grid line family |
Mon, Jul 23, 2018 at 2:17:14 PM
Grid Bubble formatting between projects |
Sun, Oct 26, 2014 at 8:33:04 AM
Column Grid Text |
Tue, Dec 11, 2007 at 9:33:36 AM
Members: | 2098557 | Objects: | 23170 | Forum Posts: | 152292 | Job Listings: | 3 |
