43 Users Online (42 Members): Show Users Online - Most ever was 626 - Mon, Jan 12, 2015 at 2:00:17 PM
Forums >> Revit Building >> Technical Support >> modify lines of medel objects in detail view?
Wed, Feb 27, 2008 at 5:09:17 AM | modify lines of medel objects in detail view?
orlilan
Hello.
I am creating a stair details sheet and have a callout of the building section as a base for the larger scale stair section.
There are a few stringer connections etc that Revit modelled not to my satisfaction.
Can I not transform the model into detail lines so that some lines originating from the model may be later altered or erased?
Do I need to trace over the entire model just because a few of the model elements are showing incorrectly and then remove the underlaying model (!?)
Thanks.
Wed, Feb 27, 2008 at 7:24:26 AM | modify lines of medel objects in detail view?
You do not have to turn off the entire model, you can use your linework tool to make some of the model lines transparent and add detail lines as required.  Sometimes you will also find masking regions useful.
Wed, Feb 27, 2008 at 1:20:24 PM | modify lines of medel objects in detail view?
JustinT
Yup use the Linework tool:
http://www.revitup.co.za/main/page_tips__tricks_i_like_linework.html
Thu, Feb 28, 2008 at 5:46:18 AM | modify lines of medel objects in detail view?
orlilan
Good stuff indeed.
And Justin, that article of yours made it all clear.
Thanks very much guys.
Thu, Mar 6, 2008 at 7:08:59 PM | JustinT
coreed
coreed Avatar
4 Stars: 16 Votes
Quoting JustinT from 2008-02-27 13:20:24
the Show Hidden Lines Tool works well for the hidden line part also
Edited on: Thu, Mar 6, 2008 at 7:10:36 PM
best regards,
coreed,aia
bmpArchitects,Inc.
Long Live Revit
detail lines
Mon, Jan 23, 2006 at 4:10:30 PM
Can you convert model lines to detail lines?
Wed, Mar 31, 2010 at 12:45:23 PM
Sidewalk to Match Topography
Tue, Jul 20, 2010 at 3:20:32 PM
Help with visibility of components and detail lines in plan view and callout?
Tue, Nov 27, 2007 at 1:12:14 PM
Detail Components with Demo Objects
Tue, Dec 30, 2008 at 4:34:29 PM
Page generation time: 2.9425
