76 Users Online (74 Members): Show Users Online - Most ever was 626 - Mon, Jan 12, 2015 at 2:00:17 PM
Forums >> Revit Building >> Technical Support >> Rotating Families in elevtion or Section, Can it be done?
Wed, Feb 27, 2008 at 12:54:04 AM | Rotating Families in elevtion or Section, Can it be done?
pattyceads
Hi Everyone,
I have created a few families for eg a M12 bolt and it is horizontal and I want to load it into a project and rotate it in an elevation/Section so it will be paralel to the roof pitch but it will not let me rotate it, why is this? will I need to try and set up a rotation parameter in the family itself or is there a way you can rotate it once loaded into the project, maybe t a Ref plane or something.
Any help would be great thanks
Patty
Wed, Feb 27, 2008 at 1:29:58 AM | Rotating Families in elevtion or Section, Can it be done?
IDN101
2.5 Stars: 3 Votes
Families adhere to the work plane of the view that they are inserted in. So I would agree that you are probably best building in an angle parameter into the family, to give you maximum flexibility.
I must say that I am intrigued that you are modelling right down to individual bolts??!!!
Regards,
Ian
www.RevitZone.com
News / Articles / Tutorials / Forums / Beginners Guide to Revit
Wed, Feb 27, 2008 at 7:19:07 AM | Rotating Families in elevtion or Section, Can it be done?
3.5 Stars: 391 Votes
Edit the family and under Settings / family category & parameters, uncheck the always vertical option.
Wed, Feb 27, 2008 at 11:45:22 AM | Rotating Families in elevtion or Section, Can it be done?
dano3d
3.5 Stars: 3 Votes
It does sound rediculous to make 3d bolt families, but I'm finding them useful.
I've attached a pdf-drawing to show the instance where I'm using them... 3d- exploded detail views.
The bolts I created are "face-based" with parameters to offset either the bolt or the nut from the insert face.
Hope this information is useful to you.
Dan-o
Wed, Feb 27, 2008 at 3:49:59 PM | Rotating Families in elevtion or Section, Can it be done?
pattyceads
Thanks Guys I’ll give that a go, and thanks for that dano that was a great help and I liked the exploded view it looks great.The reason for the bolt families is we are starting to do a bit of 3D steel detailing in revit and we set a parameter to the bolts so that we can schedule them easily for a bolt list for the fabricator. The sections and details are working out really good as well once everything is modeled to actual sizes.I have attached a M12 bolt that we have made
Wed, Feb 27, 2008 at 4:12:05 PM | Rotating Families in elevtion or Section, Can it be done?
dano3d
3.5 Stars: 3 Votes
thanks Pattyceads.
I like your bolt (very accurate). Mine is more abstract.
Wed, Feb 27, 2008 at 8:00:16 PM | Rotating Families in elevtion or Section, Can it be done?
pattyceads
Fri, Sep 26, 2008 at 11:43:47 AM | Rotating Families in elevtion or Section, Can it be done?
hadamadam
Hi guys...
I would like to download this Bolt,, witch is in the attachment,, but I can`t ?? any advice ??
Thanks
Adam
Fri, Sep 26, 2008 at 11:45:37 AM | Rotating Families in elevtion or Section, Can it be done?
hadamadam
or u can just send it to me>>
hadam_adam@yahoo.com
thanks a lot
A:dam
Fri, Sep 26, 2008 at 12:19:51 PM | Rotating Families in elevtion or Section, Can it be done?
Just right click on the link and save link as.... the file.
Families In Section View ???
Fri, Apr 10, 2009 at 10:24:52 AM
Rotating Symbol geometry without rotating leabel
Wed, May 6, 2009 at 8:33:58 AM
Rotating detail components in families
Mon, Nov 7, 2011 at 10:13:53 AM
Rotating mullions
Thu, Jul 24, 2008 at 4:27:53 PM
rotating elements in section view
Thu, May 1, 2008 at 11:24:27 PM
Page generation time: 0.8114
