33 Users Online (33 Members): Show Users Online - Most ever was 626 - Mon, Jan 12, 2015 at 2:00:17 PM
Forums >> Revit Structure >> Technical Support >> CIS/2 exporting and importing
Tue, Feb 26, 2008 at 7:42:52 PM | CIS/2 exporting and importing
chaggas
Has anyone gotten a CIS/2 export and import to work successfully in both forms of software that they are using? I am trying to export a steel superstructure from Revit Structure 2008 into ProSteel 17.2. Every time that I attempt this I am told that the export/import was successful, yet in ProSteel all of the objects show up as plates and not their assign W12x26 or HSS8x8x5/8 shapes. I am however, getting the correct ASTM material to show up. I'm using extensions for revit and exporting it from Revit to a .stp file and then importing it into ProSteel. Is there another step that I am missing? If you know of any advice or common mistake that I could be overlooking or if you've gotten this application to work with other programs, such as Solid Works or ADT, I'd appreciate any suggestion you might have. Thank you, Cynthia
Importing from & exporting to AutoCAD
Wed, Nov 2, 2005 at 10:10:24 AM
CIS/2 into Revit then to ADT.
Fri, May 4, 2007 at 6:16:57 PM
exporting and importing ifc
Wed, Oct 21, 2009 at 7:06:12 AM
Exporting from Revit and into 3D Studio Max
Wed, Oct 31, 2007 at 1:25:11 AM
Schedule Sync for importing/exporting Excel files
Wed, Mar 5, 2014 at 11:12:17 AM
Page generation time: 4.5418
