Forums >> Revit Building >> Technical Support >> Dormer windows
i cant seem to create a dormer window within an already drawn pitched roof. Wel i can but revit wil not allow me to cut the opening, Does anyone have any pointers onhow to do this correctly?
He;lp be very much appreciated
Will9000,
I don't think I understand the question. Can you post an image or clarify?
Thanks,
Tom
WITH A DORMER -
i TRY TO CREATE IT AFTER I HAVE CREATED THE MAIN ROOF.
I EXTEND THE 2 ROOFS TOGETHER TO FORM A VALLEY.
THEN WHEN I TRY TO CUT THE OPENING WITHIN THE DORMER IT DOES NOT LET ME, IT COMES UP WITH AN ERROR MESSAGE.
WITH THE DORMER I AM TRYING TO GET ALL THE FASCIA LEVELS TO LINE THROUGH. SO THERE WILL BE A TRIANGULAR SECTION OF BLOCKWORK ON THE ELEVATION WITH NO SIDE WALLS.
DOS THAT MAKE SENSE?
Please see attached file which is part of a project,
I am trying to get the dormers eaves to line through with the main roof, with blockwork to the sides of the window and also above. Revit will not allow me to do it
Any ideas?
ANY TIPS FOR THIS ANYONE?
36 Posts No Rating |
Use the opening tool to remove that section of the main roof that lies within the boundary of the dormer roof.
Dormer Windows |
Wed, May 23, 2007 at 2:23:30 PM
Room bounding in a dormer. |
Fri, Nov 8, 2013 at 2:57:00 PM
How can i get a dormer on this type of roof? |
Wed, Mar 14, 2012 at 2:58:37 PM
Dormer wall attachment issue |
Fri, Apr 15, 2011 at 1:42:00 PM
DORMER ROOF |
Sun, Mar 20, 2005 at 6:46:00 PM
Members: | 2115345 | Objects: | 23192 | Forum Posts: | 152320 | Job Listings: | 3 |
