Forums >> Revit Building >> Technical Support >> Calculatiing Egres Path
9 Posts No Rating |
Does any one have an easy way to figure out the Egress plath. In Acad I would just draw a Pline and list the length of the Pline, But in REVIT 2008 i Can't seem to figure out a way to create a connected line to list. Valkin
maybe this link can get you going in the right direction http://revitoped.blogspot.com/2007/01/egress-path.html HTH
Edited on: Sun, Feb 24, 2008 at 9:09:14 AM
That's a great solution! for a quick and dirty solution use the property line and tags, you can put it on a workset that won't show up in any other view...
" That's a great solution! for a quick and dirty solution use the property line and tags, you can put it on a workset that won't show up in any other view... " That'a a great solution also!!
9 Posts No Rating |
Thanks for the Ideas. The one from Revitop was perfect. I knew I had read that blog message once before. Mathew
eldados, I thought your suggestion was a nice trick but then I ran into a snag. I can't get any of the other properties of the "property segment line" comments / name and mark to schedule when I set them from the element properties. (NOTE - you can not pick individual segments, just all the segments created when you sketch them. And they don't have to be connected) I can modify my property segement tag to have pointers to what appears to be these parameters ... but are not the same. Instead, they point to instance parameters that have to be set in the tag for each segment. Not an easy process. This process does allow me to assign an identity to the mark parameter such as "room number" and to sort and total my distances accordingly in a schedule of exit distances. Something wrong here in REVIT.
Edited on: Mon, Feb 25, 2008 at 11:01:36 AM
WWHub, like I said this is a quick and dirty way. when we calculate eagreses we don't really schedule length and location, we just got to make sure that the path is right, normally it's the job of the fire engineer/certifier to check and approve. you won't be able to schedule the propert line, if you do, you are better off with solution one. I have attached the tag i use, just in case
3D path insteads of 2D path |
Mon, Mar 28, 2005 at 9:23:39 PM
Sketch a path greyed out...can't alter sweep path |
Mon, Jul 26, 2010 at 4:45:06 PM
Calculatiing Overall Length of Conduit in REVIT MEP |
Tue, Aug 21, 2012 at 2:35:25 PM
3D path in Revit 2008? |
Mon, Dec 21, 2009 at 3:33:01 AM
sun path size |
Thu, Feb 4, 2016 at 12:42:07 PM
Members: | 2115849 | Objects: | 23193 | Forum Posts: | 152301 | Job Listings: | 3 |
