73 Users Online (72 Members):
Forums >> Revit Building >> Technical Support >> Section problem with skp import
5 Posts No Rating |
I am trying to bring a sketchup model into revit so that I can get plans and sections of the project. Whenever I do a section cut it still shows everything behind the section cut line. Have a project do soon so any help with this would be greatly appreciated.
put your project in 3D view and see if your sketchup model it's a different level from your revit model
5 Posts No Rating |
I don't have anything that was built in revit. All I want to do is bring a completed skp model into revit and use revit to make the sections. I read somewhere in a forum that it might have something to do with it being a family and you can't section cut through a family. Any ideas?
![4 Stars: 9 Votes](/images/stars_4.gif) |
Most sketch up models and imports of this type cannot be cut. I dont know how to fix it or if its even considered a bug. But from what I have seen/ found if it wont cut it wont cut. You would have to remodel any entities that you want cut. Nick
7 Posts No Rating |
When you draw the section line, there is a red dashed box on one side of the section cut. Stuff in that box shows up in your section view so modify that box to your liking.
Bringing an SKP file into RAC 2011 |
Mon, Jul 8, 2013 at 1:41:20 AM
Import AutoCAD or SKP to Revit as 3D masses for light renderings |
Mon, Jan 5, 2009 at 6:33:10 PM
Can't import SKP file! |
Sun, Feb 8, 2009 at 3:58:59 PM
Import SketchUp |
Sun, Feb 8, 2009 at 3:00:23 AM
12
Errors when importing sketchup model into mass |
Sat, Dec 6, 2008 at 5:24:14 AM
Members: | 2017379 | Objects: | 22947 | Forum Posts: | 152212 | Job Listings: | 3 |
