51 Users Online (48 Members):
Forums >> Revit Building >> Technical Support >> Cute PDF not working
I am using Revit 2008 and just installed Cute PDF but cannot get any PDF output when trying to plot. I use a HP 1220 printer that only handles 11x17 size, so I went into printers and faxes and created a new printer using a HP 650 plotter and Cute PDF as the output with d-size sheets. Still no PDF. What I do get is a 8.5x11 blank sheet in Acrobat. Have tried all the settings for page size. Please help. Kind of stuck without this.
![cganiere Avatar](user_avatar/5565.jpg)
Try uninstalling and reinstalling Cute PDF. If that fails try one of the other free PDF writers. Did you install Ghostscript?
Christopher Ganiere, NCARB, LEED AP
www.developmentone.net
Skype: ArchitectCRG |
![3 Stars: 2 Votes](/images/stars_3.gif) |
Hi,You can download the required pdf software here. Check for many more softwares and I hope this might help you. http://www.cutepdf.com/
Thanks
Edited on: Wed, Aug 29, 2012 at 6:57:36 AM
![3.5 Stars: 4 Votes](/images/stars_3.5.gif) |
hi rfarley, if you have installed cute pdf , when printing, u select cutepdf as the printer, not another device.
the cute pdf printer gives all paper size options up to and including A1 .
you run the plot routine using cutepdf, then save the pdf to a convenient location (file) as per the prompt, once saved, then u can either email said pdf , or then print that pdf using your hp printer to get a hard copy.
cheers
mansell5
![mbsteve Avatar](user_avatar/23553.jpg)
![4 Stars: 13 Votes](/images/stars_4.gif) |
mansell has it correct, you use the CutePDF, as the plotter. I use PDFCreator, also free, and can make other formats which can be useful.
REVIT 2011 TO PDF FROM CUTE PDF PROBLEM...BLACK BORDER AROUND?? |
Thu, Nov 4, 2010 at 9:43:22 AM
batch pdf's |
Sun, Aug 21, 2011 at 2:00:55 PM
Viewport titles moving |
Mon, Nov 10, 2008 at 10:16:48 AM
multi pdf printing problem |
Thu, Apr 17, 2008 at 9:13:22 AM
imported dwg problems printing to PDF |
Mon, Dec 3, 2007 at 12:07:36 AM
Members: | 2022391 | Objects: | 22974 | Forum Posts: | 152201 | Job Listings: | 3 |
