73 Users Online (72 Members): Show Users Online - Most ever was 626 - Mon, Jan 12, 2015 at 2:00:18 PM
Forums >> Revit Building >> Technical Support >> Show above floor plumbing on 1st floor Framing
Tue, Feb 19, 2008 at 3:29:39 PM | Show above floor plumbing on 1st floor Framing
lorne17
lorne17 Avatar
3.5 Stars: 7 Votes
Ok a bit of a predicament here...
in our 2nd Floor Truss Framing Plan we show our Plumbing Fixtures above as a Heavy Dashed line.  Well, we also show the lower floor walls.  So our view is set to the 1st floor view plan, with our model shown as an underlay.  Our first attempt was to create a filter to show plumbing as a heavy, dashed, black line.  It didn’t show up that way, because the 2nd floor is not visible.  If we add 2nd floor as an underlay then it will show the heavy, dashed, line types but not the black line.  Plus we don’t want the 2nd floor walls on this plan.  Is there a way to do this properly?  Or do we just need to set 2nd floor as an underlay and use the linework tool to outline the plumbing then turn the underlay off and view the plumbing above? I can’t think of any other way to do this? Re: to the attached images.
Thanks,
Lorne
Denver, CO
Revit Architecture
1st floor to 2nd floor
Sat, Apr 7, 2012 at 10:01:21 AM
Framing Plan - Getting Walls Below Floor to Show Openings
Thu, Jan 6, 2011 at 10:11:24 AM
how to see through floor cut opening on plans?
Thu, Nov 18, 2010 at 10:02:15 PM
Framing Plan
Tue, Jan 3, 2006 at 4:10:29 PM
12
What should the Revit Structure Cut Plane Depth be set to on framing sheets?
Mon, Nov 21, 2011 at 1:44:29 PM
Page generation time: 1.5285
