96 Users Online (95 Members):
Forums >> Revit Building >> Technical Support >> Detail/Section Heads and Tails Not Connecting?
16 Posts No Rating |
Our office made our own detail/section bubbles that are a bit smaller than the standard ones that come loaded in Revit. Now when I place a new detail cut in our drawing the line connecting the tail to the bubble is not actually touching the bubble head. I made our new bubbles 1/16" smaller in diameter and now the line is 1/16" short of the bubble. It still acts like it is connected but does not display the correct way. How can I fix this?
*bump*.. having the same issue here
I can't remember exactly but I believe this was the fix. When you are editing the detail buble you have to move it over the same increment you shrink it by. So if your circle got an 1/8" smaller (radius) then you need to move the whole bubble over an 1/8" to the right (I believe). The line is preset in the software to terminate at the same point. Since you can't move the line you have to reposition the bubble in the family editor. Hope this helps...
When you edit the family, be sure to go to the VG (visibility graphics), go to the annotations tab and make sure reference planes are turned on. Most OTB Revit families of the annotation type have reference planes turned off. The insertion point of the family will be where the reference planes that are set to "defines origin" intersect. Typically in an annotation family there are only two reference planes so it is an easy task to find them. Make sure your circle's quadrant is on the intersection of the reference planes. HTH
Tom www.reviteer.com http://twitter.com/Reviteer |
That's what it was! Now I remember.....yep, turn on the reference planes!
Section Cut heads and tails automatically toggle on when you adjust crop region |
Wed, Oct 10, 2007 at 11:45:19 AM
Section and Detail Tails |
Sun, Jun 18, 2006 at 9:30:05 PM
Section Cut tails |
Wed, Mar 28, 2007 at 1:46:10 PM
Revit 2009 : Section Tails: How to create custom Section Tails |
Thu, Jul 17, 2008 at 3:25:05 PM
Section Heads |
Sat, Jun 10, 2006 at 9:49:47 PM
Members: | 2057605 | Objects: | 23076 | Forum Posts: | 152250 | Job Listings: | 3 |
