67 Users Online (65 Members):
Forums >> Revit Building >> Technical Support >> angled roof / wall
31 Posts No Rating |
I am trying to figure out the best way to model an angled roof / wall (see attached) so the curtain wall system will attach to the underside and so we can insert windows & doors. Currently the roof / wall was created as a mass element and we then need to edit the curtain wall profile by tracing the profile of the roof / wall and trimming. This does not seem like to best way to do this. You can see on the attached image the angled wall / roof is not cleaning up properly around the stair tower (on the right side of the attached image). We will also need to insert window and door openings in the angled wall. Does anyone have a better way of creating this form? Or is creating it as a mass element the best way? Thanks
Looks like the way we are doing it is the best way? Let me know. Thanks
![brettgoodchild Avatar](user_avatar/14257.jpg)
![4 Stars: 17 Votes](/images/stars_4.gif) |
You could try using the roof by extrusion and then doing a cut plan on it. (options bar) Or you could try using the opening by face tool to cut away the roof by the wall. The benefit of this would be that you create a roof and not just some mass giving the curtain wall the option to attach to the roof and adhear to it's shape. (also on the options bar) HTH, Brett
Revit 2011-putting openings in angled walls. |
Sat, Sep 10, 2011 at 5:45:27 AM
Angled curtain wall mullion |
Tue, Oct 25, 2011 at 9:57:11 AM
DRAWING ANGLED WALLS |
Wed, Feb 20, 2008 at 7:53:29 AM
Making Angled or canted walls |
Tue, Jun 3, 2008 at 2:10:07 PM
Pitched, angled & tilted roof |
Fri, Sep 26, 2014 at 2:26:26 AM
Members: | 2022271 | Objects: | 22975 | Forum Posts: | 152203 | Job Listings: | 3 |
