122 Users Online (121 Members):
Forums >> Revit Building >> Technical Support >> Model Text as a cut out
8 Posts No Rating |
Can anyone advised me on how to use model text as a void Thanks John A
This is from Mr.Spot's site: 1. Simply create your model text as you would normally and set the plane so the text is embedded on the face of the wall or system family that you want to engrave the text on. 2. Use your join geometry tool on the wall and the model text - This makes Revit cutout the model text from the wall. 3. Now just set the material of your model text to have a 100% transparency... HTH
8 Posts No Rating |
Coreed, Have you tried this method. If I select the text to be joined then the wall is not selectable. ??? John A.
8 Posts No Rating |
Hi once more, I'll revise my earlier comment. I can create a Model Text Void in a wall in a project, but not in a family. I'm trying to create stenciled signage and if i can make this method work in a family rather than a wall it will mean a lot less work. But up to now I cant seem to join Model Text to any other 3D object within a Family. John A
from what i understand it will work with elements defined as Generic models also. i have only used it to engrave in walls. HTH
Model text |
Wed, Jun 29, 2016 at 11:03:18 AM
Model Text void |
Fri, Sep 19, 2014 at 10:21:30 AM
Model text subtractions |
Thu, Jan 15, 2009 at 12:33:33 PM
Text being cut in the corner |
Mon, Apr 24, 2017 at 10:02:08 AM
missing text |
Thu, Dec 19, 2019 at 3:35:19 PM
Members: | 2030725 | Objects: | 23003 | Forum Posts: | 152205 | Job Listings: | 3 |
